87 TPI 5.0 TPS adjusting info
Old Apr 10, 2009 | 02:24 PM
seventy77's Avatar
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
I was told that if the TPS is not ajusted right,it will make car buck on take off.True? or false? The book says to adjust it between .047-.061.What is the best number to set it on?? Is throttle response better closer to the lower number or higher.I'm just trying to find out what's the best choice for setting(if any) and if bucking/running like crap has something to do with it.
Old Apr 10, 2009 | 02:47 PM
morepowerjoe's Avatar
Car: 86 Camaro
Re: 87 TPI 5.0 TPS adjusting info
All-Data says .54
Old Apr 10, 2009 | 04:49 PM
BLK02SS's Avatar
i tried last night and pulling it up all the way i could only get to the .4xx range. right in the middle of the tps sensor travel range is .05xx. set mine there and had a little over 4.0 volts and wide open throttle. throttle response is great. i want to know once and for all!! IS IT .054 or .54 volts?
Old Apr 10, 2009 | 07:40 PM
Car: 86 Camaro
Throttle Position Sensor and IAC Specifications
Old Apr 10, 2009 | 07:56 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
pre-89 = 0.54v
90-92 = 0.76v
adjust it in sequence with your idle speed, increase in idle speed = increase in tps voltage.
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
