TPI ECM bad?
Old Apr 10, 2009 | 05:48 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Transmission: TH-700R4
Axle/Gears: 2.77
TPI ECM bad?
Is there a way to check if the ecm is bad?
(My Situation)
Just dropped a 305 in my car (to replace the old one). The other one ran before i replaced it. Now when i turn the key the fuel pump goes on (sounds normal) then it sounds like its hitting a lower pitch sound. No gas is getting to the engine, there is spark going to the spark plugs. When i turn the key it starts turning over but there isn't even a sputter.
(just to let you know the fuse for my gauge cluster blew i think the ecm could have gone too)
Old Apr 10, 2009 | 05:58 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: TPI ECM bad?
Does it read out a code 12 if you jumper it?
Old Apr 10, 2009 | 09:20 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: TPI ECM bad?
Did you put all the ground wires back on the rear of the passenger side head?
Old Apr 11, 2009 | 08:36 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Axle/Gears: 2.77
Re: TPI ECM bad?
Im not sure... my brother said he put some one but wasn't sure about the rest. (Im learning as i go along this is my first car) I don''t know where to look for the grounds, because he took care of all the electrical stuff. He can't come and look cause he lives 5 hrs away.
I checked and it gave me a code 12 which is good for the ecm. (Thanks Rayvan)
Is there a place in the engine bay or underneth the car i can look to check for the grounds?
where on the passnger side head?
Old Apr 11, 2009 | 08:56 PM
jv9999's Avatar
Engine: 5.7L/350
Re: TPI ECM bad?
In the worst possible place. On the back of the head. Looks for any loose wires back there.
Old Apr 13, 2009 | 09:54 AM
speedfreak91's Avatar
Car: 1991 trans am gta
Engine: 0.060 over L98 speed-o-motive 5.7
Transmission: madd dog 700r4 w/ 34-3800 stall
Re: TPI ECM bad?
you can try slapping the ecm, but i'm not sure it will work if the car won't run...
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
Sanjay
Aug 12, 2015 03:41 PM
BOOT77
Aug 10, 2015 12:20 PM
marcusaw
Aug 10, 2015 08:13 AM
