Are vortec heads compatible with TPI motor?
Old Apr 16, 2009 | 06:14 AM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Just wondering if vortec heads go straight onto an l98 tpi motor or if they dont fit at all, or if they needs toi be modded?
Old Apr 16, 2009 | 10:50 AM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
Re: Are vortec heads compatible with TPI motor?
You need a vortec intake manifold. TPIS sells a manifold that will port match with vortec heads.
Old Apr 16, 2009 | 12:07 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
Edelbrock also sells a tpi manifold for vortec heads. Also vortec heads don't have EGR ports.
Old Apr 16, 2009 | 02:30 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
If you are going to run an EGR, you need the Scoggin-Dickey or Edelbrock (they are both the same) manifold, and you will need the Scoggin-Dickey kit to take exhaust from your headers to run the EGR.
TA
Old Apr 16, 2009 | 03:25 PM
evilstuie's Avatar
Thanks for that.
I think i'll leave it for now, was just thinking if the vortec heads were a lot better flowing than the stock then i'd get a set coz i can get a hsr for cheap for it.
but i think i'll spend the extra cash get the hsr and a set of good flowing 195's
Old Apr 17, 2009 | 12:56 AM
nelson84's Avatar
Car: 84 vette 85 vette
Engine: 350 crossfire, 350 TPI
Transmission: both 700R4
Axle/Gears: 84 vette 3.07, 85 vette 3.54
Which vortec heads to get for my 85 corvette 350 auto? Does anyone know which serial number to look for? Do some vortec heads flow better than others?
Old Apr 19, 2009 | 06:44 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
TA
so what headers can you run w/ vortec heads to be able to use this kit?
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
