TA 85 missing
Old Apr 18, 2009 | 08:03 PM
passwater's Avatar
TA 85 missing
engine is on firing on three cylinders. Just rebuilt distributor tonight still not firing on all cylinders. It has new ECM, Injectors, fuel pump, fuel line. Has about 25 miles on a new ecm and this problem started. I bench tested two injectors and work ok. Shot gas in the thottle body starts firing on all cylinders. Fuel pressure 43lbs when running. Jumper one injector to 12 volts will not fire cylinder. Shut car off watch fuel pressure gauge drop when jumpered injector. Did have a problem a couple weeks back with water in the fuel but drained tank and ran fine for 200 miles.
Old Apr 21, 2009 | 09:31 PM
passwater's Avatar
Re: TA 85 missing
Remove injectors found 6 would not spray only two would barely spray.
Found fine rust particles cleaned with mineral spirts. Fuel tank has few rust spots going to use fuel tank liner to correct problem. This car has all new fuel line, injectors, fuel pump. Didnot think the little rust in the tank would hurt anything. Fuel fuel must be letting the small particles get by.
Old Apr 22, 2009 | 08:44 AM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
Re: TA 85 missing
Glad you found your problem... did you figure out that the ECM fires the injectors by providing a ground, not 12 V. I found out when MY TPI was firing on only one bank... my son had snagged on of the 12V leads with his foot and pulled it out, so only had 12V to half of the injectors. (PO converted this '86 carb'ed V8 to TPI with a '85 setup. Kid did a mediocre rewiring job.)
Tony
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
