What Next?
Old Apr 28, 2009 | 06:23 PM
kodysformula's Avatar
Car: 1989 Formula Firebird
Engine: 5.7 TPI
What Next?
My car will not start unless I spray gas in the TPI air intake, and then it will run but idle rough, and the fuel pump flow is good. In help is good. thanks
Old Apr 28, 2009 | 08:43 PM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
Re: What Next?
if you have a fuel injector light noid. you can check to see if the pulse is good. I recently replaced my distributor due to the pickup disintegrating. I know the fuel injectors also get the info from the distributor.
Old Apr 30, 2009 | 04:28 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: What Next?
You could have a bad injector, or an ECM going out on you. The ignition module is also a possibility but they usually lose spark before they quit working the fuel, and they make the fuel pump run so I would doubt that's your issue.
Old Apr 30, 2009 | 03:02 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: What Next?
I had this same problem with my 86 IROC when I bought it. I replaced the IAC and TPS and the problem was gone. Let me guess: Throttle response is also terrible?
