NEED HELP WITH ROCKER ID
Old May 16, 2009 | 09:39 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
am looking to purchase some used crane 1.5 rockers - cheap. problem is the guy keeps telling me things that conflict.
he says the part number is p273.
they are supposed to be thin body for the center bolt - full rollers - but non self aligning. the closest that i can come are these http://store.summitracing.com/partde...ew=1&N=700+150+
but the alleged part number of p273 does not equate with those at summit.
anyone recognize these and would you use non aligning rockers with a head and pushrods designed for self aligning rockers?
pic's attached.
Attached Thumbnails NEED HELP WITH ROCKER ID-bspdgow-wk-kgrhgookjcejllmyddjbkck5yjsmg-_1.jpg   NEED HELP WITH ROCKER ID-6263_1.jpg
Old May 16, 2009 | 09:44 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Re: NEED HELP WITH ROCKER ID
Those look like Non-Self-Aligning rockers (2nd Picture). You have to have something to locate the Rocker. That means either Self-Aligning rockers, or non-self-aligning rockers with guideplates, or non-self-aligning rockers with cylinder heads that locate the pushrod via the pushrod hole. You don't want two conflicting methods either..
Using these rockers on an engine designed for Self-Aligning rockers will mean that there will be nothing to keep the rocker from sliding off of the valve.
Old May 16, 2009 | 09:53 AM
Car: 1990
Axle/Gears: stock
thanks for that info - i was thinking that way myself - but what the heck is a p273 for a part number? and if i get non self aligning i will have to install guide plates and also change my push rods to something that will not wear rubbing against the plate - probably not a good idea, i am trying to keep it simple.
thank you
Old May 16, 2009 | 10:15 AM
thirdgen88's Avatar
Car: 1995 Corvette
You are correct on both counts, if you use those, you will have to use guide-plates, which will subsequently require the use of hardened pushrods...
Old May 16, 2009 | 11:55 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I'd pass on those rocker arms. There's one that looks pretty chewed up.
Old May 16, 2009 | 12:17 PM
Car: 1990
Axle/Gears: stock
i was only going to use 8 for the exhaust but i want self aligning ones so i dont have to buy different stuff.
i just want 1.6 for the intake and 1.5 for the exhaust, but they have to be skinny for center bolt too.
but i appreciate your pointing that out - i could have missed it. this is new ground for me when it comes to all the different rockers. 1.5 - 1.6 - 447/510 cam - computing different lift and spring limit to 530 and heads that max out at about 470 and shims - offset clips - darn that is a lot of math for an old man!
i am pretty lucky to have people like you and the others to help me out because i would never have known the correct answer to all that.
now i know that what i need is thin rockers - did not know that one until i was told - and i got the numbers on the cam v lift - i was told that - got max springs stats on zz4 springs - i was told that - it goes on and on and this is board and the people on it have kept me looking in the right direction.
thanks to everyone.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
