Sluggish on rebuild
Old May 22, 2009 | 01:50 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Sluggish on rebuild
Hi Everyone,
I recently finished my rebuild and took the car out the other day. It seemed sluggish and didn't want to pull hard like it did prior to the rebuild.
I took the engine out and had the following done...
-cylinders bored .030 over
-connecting rods cleaned/refurbished
-new flat top Speed Pro pistons with coated skirts (about 10:1 compression)
-rotating assembly balanced
-added 2500 rpm Hughes stall converter
Other than these changes, everything in my sig (heads, cam, etc) is the same.
I checked and the TPS sensor is at .60v. No fluid leaks. Base Timing at 8*.
Does anyone have any ideas as to what I can do to fix the sluggish issue?
Thanks!!!
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
