Fuel pressure when cranking
Old May 31, 2009 | 11:20 AM
TPIMonteLS's Avatar
Transmission: Automatic!
I searched but wasn't able to find an answer, what should fuel pressure psi be when cranking the engine? Key on engine off its right about 40, when I crank it dips to the upper 30's to maybe 35psi. When running its at 42-44psi. The car has has cold start issues since my swap and I'm trying to narrow it down, just wondering if this is normal or not. Also if I hear the relay prime with the key on engine off, is it safe to assume the relay and connections are fine?
Old May 31, 2009 | 05:24 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Fuel pressure when cranking
Key on engine off = no vacuum, 40 would be fine.
Key on engine crank = low battery volts (mine drops to 9 volts during crank some times), low fuel pressure.
Key on engine run = high volts (14.2) and high vacuum, so 44 psi would be fine.
Try disconnecting the vacuum line from the AFPR when running, to see the total change, 7 psi is typical.
Cold start issues are going to be fuel (pulse width) and spark advance related.
92camaroJoe
Jul 29, 2023 07:57 PM
Bryan F
Aug 18, 2015 02:28 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
