tuning 355 HELP
Old Jun 3, 2009 | 08:33 PM
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Transmission: MK6 Manual
Axle/Gears: 3.45
tuning 355 HELP
just dropped my 355 in. changed injectors, chip, headers, no air pump or a/c, roller rockers. set fuel at 50 psi and timing at 10 degrees btdc. runs ok but was supposed to be a 350 plus horse motor. any tips?
Old Jun 4, 2009 | 08:52 AM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: tuning 355 HELP
What kind of cam/heads are you running? Is it TPI? Is the chip you put in a stock chip or a custom burned? Could deffinatly use some more details on the motor. What's the problem? Is it just not performing how you expected?
Old Jun 4, 2009 | 07:27 PM
johnnyph1's Avatar
Car: 1989 Formula
Engine: TPI 355
Axle/Gears: 3.45
Re: tuning 355 HELP
it just doesn't seem to have the power I expected, and it surges like crazy, no matter what I do. Have a Hypertech chip Thermomaster 128922 and Comp Cams p/n 08-302-8. had the engine built balanced and bluprinted by a very reputible shop. Made sure tps is set correct. Adjusted the timing from 6 to 15 degrees. seems to run best at factory to 10 degrees. Just swapped from 305 "f" motor. The 305 had headers, cam,chip, and I think that's bout it and the 355 doesn't really seem that much faster if at all. Dunno if it matters that much but just looked at the box for the chip and it says "auto" my car's a 5 speed. p.s thanks for your quick response....
Old Jun 4, 2009 | 09:32 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: tuning 355 HELP
you need to custom tune your chip. mail in wont work.......
darwinprice
17
Oct 11, 2015 11:51 PM
