406 Super Ram- fuel pump
Old Jun 13, 2009 | 05:50 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I am going to start my car tomorrow after dropping in the new engine.. My question is will my stock fuel pump support this setup or should I replace the fuel pump after breaking in the cam. I hoping the stock pump will cover it but I am not so sure.. Here's the Setup.........
Chevy 406
Comp XE 284 cam
Brodix 200Ik heads
Super Ram Intake
30LB injectors
Should make around 500 FWHP
Old Jun 15, 2009 | 11:04 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: 406 Super Ram- fuel pump
The stock pump will not keep up.
Old Jun 16, 2009 | 02:09 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yeah, you'll need to drop the fuel tank and install a better pump. We use ones made for the Syclone/Typhoon/Grand National.
The stock pump might keep up at idle but it wont handle it under load. You'll go lean.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
