Mass air to Speed Density conversion
Old Jul 17, 2009 | 05:51 AM
M&M_GTA88's Avatar
Car: 1988 GTA
Engine: 383 Stroker L98 TPI
Transmission: 700 R4 w/ B&M Shift Kit
Axle/Gears: Stock BW LS 9 Bolt with 3.27 gears
Can a mass air system be converted to a speed density system? If yes, what needs to be done to achieve this coversion?
Thanks,
Mike
Old Jul 17, 2009 | 08:07 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Mass air to Speed Density conversion
There's a ton of info if you use the search feature.
CHAPTER 4: MAF vs. MAP: CONVERSIONS AND DEBATE
https://www.thirdgen.org/forums/diy-...uide-book.html
Old Jul 20, 2009 | 07:16 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Go to the main page of this website: https://www.thirdgen.org/
Look on the left side at the tech articles section, then read the link about converting from MAF to Speed Density.
Come back here if you have more questions.
Old Jul 20, 2009 | 09:01 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
There are three ways to do the conversion.
1. Completely swap in a MAP harness from a donor 90 to 92 TPI MAP car.
2. Repin your MAF harness to MAP. (not easy and requires a lot of advanced skills)
3. Purchase a convertor harness from Street and Performance(By far the easiest way to do it. See this link from there catalog.
Use the links on the side and go to page 66.
http://www.hotrodlane.cc/08%20catalo...talogMAIN.html
Old Jul 21, 2009 | 12:53 AM
Kevin91Z's Avatar
1. Check the pinouts in the firewall on an 88-89 MAF harness compared to a 90-92 MAP harness. They're different and you will be connecting a 12v power source straight to a ground source. That'll give you a direct short and a nice smoke show.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
