Please explain what speed density is
Old Jul 25, 2009 | 07:56 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Sorry if this has been asked, but I didn't see it. To my understanding, my 1992 z28 is a "speed density" vs. "MAF" car? Exactly what does this mean?
thanks for the help.
Old Jul 25, 2009 | 10:00 PM
skinny z's Avatar
Re: Please explain what speed density is
Here's a little reading for you. It should answer your question.
http://www.carcraft.com/techarticles...ion/index.html
Old Jul 25, 2009 | 10:16 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
They are two different ways for discharging fuel into the motor based upon air flow to the engine. Below are some links. Modifying your engine will require you to tune your cars computer. MAP is not bad, just good to know what type you have since that will affect how you mod and tune your engine. MAP sensor is located at upper right part of engine bay near driver side if you are looking at car from front bumper. It is to the right of brake booster assembly. I believe it connects to rear left side of intake plenum.
http://en.wikipedia.org/wiki/MAP_sensor
Check out this post too
https://www.thirdgen.org/forums/tpi/...d-density.html
Old Jul 25, 2009 | 10:24 PM
jtsk's Avatar
Thanks guys for the articles. Much appreciated.
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
RGB2015
Sep 20, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
