cylinder select error
Old Jul 26, 2009 | 11:28 AM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
i am having a guy tune my ECM and it keeps coming up with a cylinder select error. is that an error on his side or is that an error with a sensor or something along that line with the car.
Old Jul 26, 2009 | 12:56 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: cylinder select error
Memcal is probably wrong for the application
Old Jul 26, 2009 | 03:29 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
what is a memcal memory calabration?
Old Jul 26, 2009 | 10:36 PM
JP86SS's Avatar
https://www.thirdgen.org/forums/dfi-...om-calpak.html
This is a sticky in the DFI & ECM board.
there is a resistor(s) that indicate if the Memcal is for a V6 or V8.
Cylinder select error indicates the software is stating one thing and the hardware is for another.
there are ways around this if needed. Search memcal in the DIY-Prom board.
Old Jul 28, 2009 | 11:06 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
ok i get this now the ecm is the stock 350 ecm that GM installed in the car. the guy that is tuning the car said he changed the cylinder select to 8 in the computer what should it be set at 0?
Old Jul 29, 2009 | 06:14 PM
JP86SS's Avatar
Yes, It should be 00 for 8 cylinders in that application.
If you still get that error, The memcal is from a V6 or other.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
