4.3l Injector size?
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
4.3l Injector size?
I recently got an intake from a 1995 caprice with the 4.3l v8. I have tried to find what size the injectors are. Does anyone know? thanks
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: 4.3l Injector size?
Best for sure way to know.....get a part number from off the side of injector, search on that.....Some lt1 motors (93 corvette) run a small injector, so that one I would suspect to be 18-22lbs
Car: 89 iroc
Engine: l98
Transmission: tremec
Car: 1983 G20 Chevy
Transmission: 4L60
I think they were 200 HP and 240-250 TQ depending on the year. It is basically a 305 version of the LT1 with a 3" stroke crankshaft and 5.94" rods. (3.735" bore and 3.00 stroke) The cylinder heads are almost identical to the L30 305 Vortec.
On a 1994 Caprice the stock injector flow constant is programmed at 19.45 lb/hr.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
