Hot start issue
Old Aug 15, 2009 | 01:44 PM
88ROC1LE's Avatar
Hot start issue
Old Aug 16, 2009 | 04:47 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: Hot start issue
i would start with ALL electrical grounds
Old Aug 17, 2009 | 04:33 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Hot start issue
Test your ignition coil and module.
Ohm out your injectors.
Old Aug 17, 2009 | 08:13 PM
88ROC1LE's Avatar
Re: Hot start issue
Old Aug 18, 2009 | 12:43 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: Hot start issue
check all the wires for chaffing. Also, what is his base timing at?
Old Aug 18, 2009 | 04:15 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Hot start issue
Might want to verify that the plug wires are on the dizzy in the correct order and that it's timed correctly.
Old Aug 18, 2009 | 12:08 PM
88ROC1LE's Avatar
Re: Hot start issue
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
