Injector dead to the touch, bad injector?
Old Aug 18, 2009 | 10:09 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Alright folks.
My question is simple....
I can physically touch my finger to my injectors and feel them clicking/pulsating, but my #6 injector is dead to the touch, as in i don't feel anything...
No clicking, no pulsing, nothin, i've yet to hear it with a stethoscope/screwdriver...
Could i have a bad injector?
Old Aug 19, 2009 | 05:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Injector dead to the touch, bad injector?
Maybe.
Ohm check it.
It could also be a break in the wire going to that injector.
Old Aug 19, 2009 | 10:33 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Originally Posted by Viprklr
Maybe.
Ohm check it.
How can i find out if there's a break in the wire?
Old Aug 19, 2009 | 11:21 PM
Awesome-X's Avatar
Car: 87 Camaro
Uhh trace it? lol but in all seriousness ohm test the injector first. If it tests bad then swap another injector that you know is good in its place and see if it fires like it should. If it doesn't and you can safely say the injector is good then you can narrow down other possible causes from there.
Old Aug 20, 2009 | 07:28 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
swap the conn from a different inj on to #6 if it still doesn't work then the injector is bad,
if it does work then you have a problem with your wiring.
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
