still need help
Old Aug 21, 2009 | 12:59 PM
89tpirocamaro's Avatar
Car: 89 camaro iroc z28
Engine: 355 carbed
Transmission: t-5 speed
Axle/Gears: 2.73 posi drum rear
still need help
my 89 305tpi camaro has a problem. when i first start it up( motor is cold) it drives and runs fine. when i shut the car off and go to start it again (motor is warm) it wont start. its at the shop and they tested the wires that cap on to the fuel injectors and when hot the light is very dim compared to very bright when cold. they just put in a new distributor, ignition coil so its not an ignition problem...... starting to think that the problem is in the harness because my car sat and mice made a home inside the dash.....someone please give me some answers so i drive my car
Old Aug 21, 2009 | 05:29 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: still need help
Ohm your injectors first.
Get the ignition module tested.
Come back with the results.
Old Aug 22, 2009 | 08:05 AM
Engine: 355 carbed
Re: still need help
injectors are fine, control module is new,
Old Aug 23, 2009 | 12:21 AM
firebird310's Avatar
Car: 89 FORMULA 350
Axle/Gears: 327
Re: still need help
I HEARD THE INJECTORS SHOULD READ 15 OHMS
