Programmer Question
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
Programmer Question
Is the Moates Burn II programmer the same as a chip programmer or a real time programmer or do they have totally different purposes?
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: Programmer Question
You have to use something like Tunerpro RT or Tunercar I and a computer with the Burn2 hooked to USB port to re-program chip. You'll also need a moates eprom adapter and some re-flashable eproms.
Need to start at DIY PROM in the stickies.
You'll get the hang of it.
