87tpi into a 91
Old Sep 15, 2009 | 04:51 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
87tpi into a 91
Hi i have a complete tpi system off a 87 camaro and was wondering if i could put it in my 91RS because i am wanting to put a 350 since my engine needs some head work. Or would i be best of just going to a 350 tbi instead of tpi.
Old Sep 16, 2009 | 04:18 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 87tpi into a 91
There's more work involved in using the TPI setup. You'll need the ecm and harness.
You'll be much more happy in the end going with TPI over TBI.
Old Sep 16, 2009 | 01:16 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 87tpi into a 91
What else would i need because i also have the wiring harness and ecm
Old Sep 18, 2009 | 06:43 PM
IrocTheZ28's Avatar
Car: '92 Z28
Engine: 350 TPI L98
Axle/Gears: 10 Bolt / 3.23
Re: 87tpi into a 91
You're clearly in violation of California Emissions Laws if you install older engine parts and expect to pass under the smog check referee.
It's explained in this link >> http://www.novak-adapt.com/knowledge/emissions.htm
My guess is the referee personnel are highly trained to spot these conversions.
Just posting to help out save you a headache.
Old Sep 19, 2009 | 10:10 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: 87tpi into a 91
An '87 harness will not work in a '91.
Like the man said, you need the '91 harness and ecm
Old Sep 19, 2009 | 10:59 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 87tpi into a 91
OH ok i will have to look for a ecm and harness of a 91 then would the painless one work or should i try to find a factory one.
87t-5.0transam
Northern California
Mar 28, 2014 05:54 PM
OUTATIME GTA
Northern California
454
Jun 15, 2011 09:25 PM
OUTATIME GTA
Northern California
182
Feb 20, 2011 10:06 AM
freebird87
Jul 29, 2009 09:27 AM
primo
May 18, 2003 01:12 PM
