Edelbrock Runners not sealing.
Old Sep 21, 2009 | 10:15 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Alright so I picked up a set of eddy runners for dirt cheap. And turns out that the driver side rear didnt seal to the intake. I havent tried yet but my buddy has acces to a mill so im thinking 0.01" would almost do er good. Also i noticed the base to runner bolts on both runners, one has a heli coil and one is completely stripped.
I know this sounds like i am whining but im kind of choked. Im thinking about just heli coiling the other side and getting the runners beadblasted and act like nothing happened. . Because there's no way that coil will let lose while driving right?
I just want to know if you guys have had the same experience.
Thanks!
Old Sep 21, 2009 | 10:39 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Edelbrock Runners not sealing.
I just installed mine and had sealing issues. It turned out that I needed the Edelbrock gaskets to get it to work. The runners also had to be clearanced around the fuel rails. I would get those gaskets before I started milling material off.
Old Sep 21, 2009 | 10:43 PM
Stangski09's Avatar
Haha, buddy had the gaskets I guess. What im gonna do is pick up the gaskets and bolt it up to the baseplate and see. Then mill that little bit off until it's just right. Or I may try sealing it with silicone gasket maker. .
Linson
Oct 24, 2025 02:00 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
