fuel pump primes whenever?
Old Sep 28, 2009 | 11:45 PM
SanFranCyco's Avatar
Car: 87 GTA
Engine: L98 5.7 24#inj,World hds,MSD,nosmog
Transmission: 700R4 truck clutches,Trans go shift
Axle/Gears: 10 bolt chevy 3.73 limited slip
The problem i'm having is it seems my fuel pump is priming without the key in.i have come out to hear the pump running for no reason and on multiple occasions my battery was drained.now mind you it does it at random and not on a set schedule.any help would be highly appreciated.
Old Sep 29, 2009 | 03:33 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel pump primes whenever?
Check the wiring at the FP relay.
The connectors used on the older cars commonly loose the insulation meaning you can have power direct to the pump full time if wires touch
Old Sep 30, 2009 | 01:06 AM
Car: 87 GTA
thanks will do
Old Sep 30, 2009 | 02:16 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If relay checks out OK , check the oil pressure switch at the back of the block.
If that was to go bad , it also could supply power direct to the pump with the key off
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
