convert tpi to another small block questions
Old Oct 13, 2009 | 04:00 PM
1BAD89's Avatar
its just a straight forward swap form one 350 (stock) to another 350(older block) cause i have a mild 350 that came out of my brothers pick up and was wondering if i could just swap my tpi sytem to it cause i would like to keep it fuel injected i understand that i would have to put bigger injectors. but it would just bolt up right???
Old Oct 13, 2009 | 04:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: convert tpi to another small block questions
Only difference may be the late cast iron heads have the center 2 intake bolts at a different angle so you have to elongate those holes to fit earlier (pre 86 ) heads.
Otherwise it's a bolt up
Won't have to change the injectors ( 350 to 350 ) but may need a retune to get best out of new combo
Old Oct 13, 2009 | 05:35 PM
1BAD89's Avatar
thier aluminum heads so i should be good thier thanks for the help
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
