Cam suggestions LTR
Old Nov 18, 2009 | 06:50 PM
goleafsgo143's Avatar
Car: 86 Iroc-Z
Engine: L98 350 TPI
Transmission: 700R-4
Axle/Gears: 3.23 Posi
Cam suggestions LTR
Hi guys, I just put my Iroc away for the winter and am planning to do an engine rebuild in the spring. The car is my daily driver in the spring – fall months and will rarely ever see the track. I plan on keeping my displacement 350 or possibly bore it out to a 355 with all new internals. I think I have narrowed my heads down to either AFR 180s or Trick flow 23s. I also have AS&M Long Tube runners and an Edelbrock high-flo base. I think I will end up keeping this intake since it is a street car and will keep the fun factor with all the torque (plus it was pretty expensive). My question is the cam. I think I am aiming towards comp cams XR276HR or possibly one up XR282HR.
XR276HR - @.05 in. 224 ex. 230 110 LSA
XR282HR - @.05 in. 230 ex. 236 110 LSA
Would these cams be too much for a LTR intake or are there any better options? I am looking for a cam with a noticeable choppy idle and obviously good power to match the heads and intake. I also plan on getting a higher stall converter and keeping my stock 3.23 gears. Let me know what you think. My goal is over 300rwhp with this set-up with the right tune.
Eric
Old Nov 19, 2009 | 12:32 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Cam suggestions LTR
The 282 is definately wrong; guys are running that duration with Minirams >6500 ; way past TPI range
Some TPI examples
TPiS recommend their ZZ9 cam on aTPI with head mods
212 /226 .483/.520 LSA 112
Lingenfelter
# 74216 Camshaft TPI - 213/219 .493/.502 HR112
# 74211 Camshaft TPI - 211/219 .530/.560 HR112
Even at those figures they recommend a 2200- 2800 stall for best performance
I had great success with the ZZ4 cam and TPI intake mods; approx 320Hp
208 / 221 .474 /.510
Cheap new ZZ4 engine take out cams around @ $80 - $140
Old Nov 19, 2009 | 07:21 AM
Car: 86 Iroc-Z
Engine: L98 350 TPI
I thought the 282 was high for sure but I just picked it because I used the camquest software and it recommended it as the first choice with my set-up. The 276 was in there as a recommendation as well. I plan on getting a high stall converter so that wont be a problem for me.
Old Nov 19, 2009 | 04:02 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
What about the Comp Cams XFI 268?
(adv 268/280, @.050 224/231 , .520,.515 lift, 113 lsa
lt500r55
Sep 1, 2021 01:30 PM
stalkier
Dec 6, 2015 11:25 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
drathaar907
Aug 6, 2015 04:20 PM
