TPI HELP!! injectors not pulsing!!
Car: 1984 Trans Am
Engine: 355 TPI
Transmission: 700rv
hello everyone... i am having trouble with my TPI conversion on my 84 trans am... i know the car runs because it used to start... all of a sudden it stopped turning on it just cranks.. i am running the holley stealth ram with an accel 1000cfm t/b venom 36lb injectors... brand new speed density harness with new ecm and chip... i have narrowed it down to the fact that its the injectors not pulsing... i already switched the module from the distributor and i am getting power from my ecm.. there is spark... there is plenty of fuel...fuel is getting to the rails.. 40pounds of pressure... i am lost can anyone help .. thank you
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: TPI HELP!! injectors not pulsing!!
I'm not familiar with the retro fit kits so....
Are your 2 injector fuses blown?
Sanjay
Aug 12, 2015 03:41 PM
