Carb to TPI questions?!?!?
Old Dec 11, 2009 | 11:05 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I converted my 90 camaro from tbi to carb because of problems with a cam i bought that did not go well. I was looking to purchase a new carb when i realized i can get a tpi set up for a few extra bucks and get my car running beautifully. i just have a few questions. Will any ECM i get work or does it need to be a certain one? with a 305 which injectors will i need? what sensors do i need? If there is any thing else i need to know please tell me
Old Dec 12, 2009 | 12:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Carb to TPI questions?!?!?
Would be easiest to find a same year TPI parts car and get the wiring harness , ECM and sensors out of that.
Old Dec 12, 2009 | 07:43 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
I stripped the ac from my vehicle and i dont have the smog pump hooked up. Are you saying that if i dont get a harness out of a 90 tpi setup then i will run into problems? I also dont have a carbon canister i doesnt effect the tbi i wont need it with tpi will i?
Old Dec 12, 2009 | 03:42 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
No just that it would be easier starting with a TPI harness instead of having to modify and add connectors to yours
Old Dec 12, 2009 | 08:06 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
I realize that and i plan on getting a tpi harness but couldnt it be out of any tpi camaro? not just a 90. also does anyone know if i could get one from any other tpi vehicle and would it work? Also the the computer from a v6 will work as long as i change the prom correct?
Old Dec 12, 2009 | 09:15 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Anything is possible ; just that '90+ are SD and earlier cars are MAF so some different connectors
What TPI system are you installing ; MAF or SD ?
You need the computer ( '165 or '730 ) from any car to match whichever setup you are running along with the correct prom
Old Dec 12, 2009 | 11:18 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
could someone please explain the difference between MAF and SD how can i tell the difference will an SD harness work with MAF and the other way around? are any parts interchangable.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
