355 carb to FI...what do i need?
Old Dec 13, 2009 | 10:03 AM
ajblbv's Avatar
Car: 83 Z28
Engine: 355
So right now I have a 355 completely carbed without any computer involvement in an 83 z28. I was pondering what I would need to go to fuel injection. Would a computer from a 350 have the proper parameters for fuel and such for a 355 also? Or would that not work? I know I would need the computer, ecu, knock sensor, intake manifold, intake, fuel injectors, fuel rail....am I missing anything? Also new fuel pump and fuel lines possibly.
All input is welcome, thanks.
Old Dec 13, 2009 | 10:20 AM
Russ-So Cal's Avatar
Re: 355 carb to FI...what do i need?
You would also need a fuel return line going back to the tank in addition to all of the things mentioned. Your best bet is to find a complete fuel injection system in the junk yard to get everything. If you get one off a 305, you will probably need bigger injectors; and you will need a new knock sensor because the 305 and 350 are diffferent, and the knock sensors won't interchange and work.
Old Dec 13, 2009 | 10:39 AM
ajblbv's Avatar
Car: 83 Z28
Engine: 355
So the injectors and knock sensor are the only different things? Would the computer from a 305 also work? How do I figure out of my 83 z28 came stock fuel injected or carbed? Thanks for your input, I am just starting to read up on this and get into the gritty details. I know it's a big job, but that's why I have this car, to learn and have fun.
Old Dec 13, 2009 | 06:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Doesn't matter what the computer came out of so long as it is compatible with the intake setup (SD or MAF) being run
Need a chip for a 350 though
codeysabatini
Nov 10, 2015 04:07 PM
2012sergen11
Oct 13, 2015 07:38 PM
Damon
Sep 26, 2015 04:29 PM
BLK87Z
Sep 18, 2015 11:29 PM
Billy Decker
Sep 4, 2015 03:46 PM
