Quick question.
Old Dec 19, 2009 | 12:23 PM
AZKIKR1010's Avatar
Quick question.
I know there's a few post on here about base timing, but my question is why my car with the EST unplugged has a base timing of 4 BTDC, and with the EST plugged in it jumps to 12 BTDC. Any help would be appreciated.
Old Dec 19, 2009 | 05:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Quick question.
Because with the connector unpluged you are at the advance set by where the dist is in the block.
Once you plug the connector in the computer then has control and advances the spark ( as it should ).
That is why you have to unplug the computer when setting timing because you will be fighting against the computer
Old Dec 26, 2009 | 05:51 PM
AZKIKR1010's Avatar
Re: Quick question.
i was just wondering if it was correct cause 12-14 degrees seems like alot, but thanks.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
