Injector Leak???
Old Jan 8, 2010 | 09:17 PM
kickass92z's Avatar
Car: 92 Z28/86 T/A/98 R/A T/A
Engine: 355,355,LS1
Transmission: T-56,700r4,T-56
Axle/Gears: 3:73,3:42,3:42
Injector Leak???
My 92z is running like crap when I first start it. I can't start it and leave it. It acts, or is actually loading up really bad. I checked the fuel pressure and it is good, but if I leave it, it is 0 pressure when I come back. Once I run it and clear it out, it warms up and is fine. If it sits for a few hours it does the same thing. It is a mild 355,cam, head work, tune, yada, yada.. Anyone think it is the injectors leaking off? Or maybe the tune at start-up??
Old Jan 8, 2010 | 11:23 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: Injector Leak???
it sounds like either the injectors are leaking down to me. i could also be the fuel pump losing the prime. i had the same problem, ckecked fuel preasure and it read fine, until it cut out one day and never came back
Old Jan 9, 2010 | 09:00 AM
kickass92z's Avatar
Engine: 355,355,LS1
I hate to pull the injectors and replace them, especially if it is the start up tune. I am just starting to learn about the tuning so I may do the injectors...
Old Jan 9, 2010 | 02:53 PM
southbay08's Avatar
try pulling the plugs and if one of the cylinders is wet then you have a leaky injector
Old Jan 9, 2010 | 03:27 PM
kickass92z's Avatar
Engine: 355,355,LS1
That is the next thing I could try. I talked with a friend of mine earlier, and he reminded me of something. He had a 91z and it wouldn't start, it acted like it was loading up. It ended up being the temp. sensor. It was reading really low, so the comp was flooding the engine with fuel. How would I check the temp. sensor? I may have to break down and take it somewhere....That sux....
92projectcamaro
Jan 18, 2016 08:00 AM
ramicio
Sep 6, 2015 11:25 AM
greenyone
Sep 2, 2015 03:39 PM
mike_c
Aug 27, 2015 04:32 PM
