Quick heads question
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Quick heads question
Depends what year head and what year intake, but they can be made to work in any case.
Car: 89 iroc
Engine: carb 80 over 350
Transmission: 350
Axle/Gears: 10 bolt 373 (had 9 bolt)
if i remember right i think theres only 1 bolt hole that dont line up right.
Well, Its going to go from an 87 corvette, don't know what it has (tpi, carb, or tbi). If it is anything but tpi I am going to put my 305 tpi set up on it. And change injectors and ecm
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
On to or from '87 Vette?
'87 Vette heads are alum ; have same 6 bolt intake pattern and angle as normal SBC heads
F-Body cast iron heads have same 6 bolt pattern but different bolt angle on the 2 center bolts
NinjaNife
Aug 23, 2015 11:49 AM
