max lift
Old Mar 3, 2010 | 11:34 PM
effinbird's Avatar
max lift
i bought a set of 083 heads the other day and the guy i bought them from already installed a set of comp cam springs in them, although he forgot the specs on them. they look like a set of 986-16s but he thought the max lift on them was only.480 but he wasn't sure. my question is is there anyway to measure a springs max lift? because im running a lunati 60101 cam and would like to put 1.6 rockers on it but that would put the exhaust valves at .499 lift and don't want to just through them on and damage anything. any help would be appreciated.
Old Mar 3, 2010 | 11:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: max lift
Compress the spring in a vise until the coils bind, then measure the height. Subtract that plus a safety margin from the installed height.
Old Mar 4, 2010 | 12:22 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: max lift
you need .060"min between the coils at max lift.
Old Mar 5, 2010 | 08:33 PM
effinbird's Avatar
Re: max lift
alright ill have to try that and figure it out thanks for the help. my only other question now is do you think the stock l98 heads can handle that much lift
Old Mar 7, 2010 | 07:20 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: max lift
https://www.thirdgen.org/forums/tpi/...m-big-tpi.html
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Jorlain
Oct 8, 2015 01:57 AM
Gordonr1973
Sep 29, 2015 11:59 AM
