'89 TPI doesnt accelerate when cold
Old Mar 22, 2010 | 09:05 PM
alexr's Avatar
Car was running great, then one day after the engine got a bit hot, after starting it, it would buck hard when I hit the gas, I barely made it home - as if its not getting fuel. Now, it bucks when cold, takes awhile just to get up to 50MPH. Once engine warms up its much better and I can drive it on the highway fine. When cold, it stalls during startup.
Replaced cap& rotor and ignition coil, will do plugs and wires next. Fuel Pressure at rail is 40 PSI (normal). Need to check EGR. Unfortunately, it could be a *million* things like vacuum related, or electronic related like pick-up coil or ECM in the distributor, or a bad sensor, or fuel related like
pump, filter, pressure regulator, and/or injectors. Tach is reading fine, there are no unusual noises either.
Anyone have this problem and what did you do to fix it? Any advice is helpful.
(In the past I've had wierd problems like "would not start" and to fix that I replaced the temp sensor (it always read "warm" and the computer did not supply the required "richness" to get it to start).
Thanks, --Alex
Old Mar 22, 2010 | 09:47 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: '89 TPI doesnt accelerate when cold
Does it idle well? How's the timing? I literally parked my S10 before class, was running fine. Came out a few hours later, sounded like the engine was gonna come right out from under the hood it was bucking so bad. Turned out to be a bad dizzy, and the timing was way off.
Old Mar 22, 2010 | 11:10 PM
southbay08's Avatar
you might want to check all sensors, then injectors
www.southbayfuelinjectors.com
stalkier
Dec 6, 2015 11:25 PM
destroyerwes
Aug 26, 2015 08:17 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
