305 questions
Old Apr 2, 2010 | 01:45 AM
92formula12's Avatar
Car: 1992 Firebird Formula
Axle/Gears: Posi
305 questions
I have a couple of questions with the 113 casting heads work on a 1992 lb9 ive researched this alot and have not found a good answer i know they will bolt up they have the same 58cc combustion chambers will the 1.94 valves clear the 305s bore?
Old Apr 2, 2010 | 07:48 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: 305 questions
https://www.thirdgen.org/forums/tech...05-viable.html
Yes you can, but there are a lot of variables that could cause a problem, so it's always best to do a careful mock-up first.
Slight differences in castings, dowel positions, and cylinder placement can throw things off enough to cause a problem. It rarely happens, but ALWAYS check first.
84z96L31vortec
Aug 20, 2017 12:16 AM
dutch930
Sep 11, 2015 06:58 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
