LT1 injectors
Old Apr 12, 2010 | 05:15 PM
TheNewStyle's Avatar
Car: '88 Formula
Axle/Gears: Stock
LT1 injectors
Guys will standard lt1 injectors work in my stock tpi system? Meaning are they standard 14mm and will they connect with my factory plugs?
Old Apr 12, 2010 | 11:47 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: LT1 injectors
lots of TPI guys run stock LT1 injectors, should be fine. The only issue I know of is a height issue with guys running LS1's injectors on tpi. Requires some modification
Old Apr 14, 2010 | 07:07 AM
Car: '88 Formula
Axle/Gears: Stock
Re: LT1 injectors
So standard LT1 injectors should work with my stock ECU plugs? That would be great!
Old Apr 14, 2010 | 09:17 AM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 injectors
They fit fine
Im using TPI injectors in my LT1 intake/rail. No height issues
New2Chevy
Sep 28, 2015 12:35 AM
webeeZ28
Sep 14, 2015 12:00 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Keiffer76
Sep 9, 2015 08:52 PM
L0tuS
Sep 4, 2015 11:16 PM
