Injector limits
Old May 3, 2010 | 07:16 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Injector limits
Anyone know what peak HP injectors are around the 80% duty cycle on 22 24 26 lb injectors?
Old May 4, 2010 | 08:32 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Injector limits
Injector Calculator
22lb/hr ~ 280hp
24lb/hr ~ 305hp
26lb/hr ~ 330hp
Old May 4, 2010 | 11:50 AM
transamice's Avatar
Car: 87 GTA t-top
Re: Injector limits
Would 26lb injectors run too rich on a stock 350?
Bottom line is Im thinkning of adding a turbo at 4 psi.
Im reading about other setups running on 24lb injectors upto 6psi claiming to get 400 rwhp.
Im not expecting to reach 400hp but around the 330 would be nice.
I have to add, your bird looks amazing, lots of work lots of love. The gauges man, I love it.
Old May 4, 2010 | 11:55 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Injector limits
i would think they should...id try 22 or 24's....
Old May 4, 2010 | 02:15 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Re: Injector limits
They will be fine but you will have to get a custom chip burned.
Old May 4, 2010 | 09:56 PM
redcorvette's Avatar
Car: 85 vette
Engine: 427 SHP block,AFR 210,MiniRam
Transmission: TKO 600
Axle/Gears: 3:07
Re: Injector limits
When you run the injector calculator program you will notice that you have to change the brake specific fuel consumption from .5 to .6 for a turbo engine, thus requiring a larger injector.
The 80 % number is for helping select an initial injector size by giving you a little leeway, not a hard number you must hit for proper operation. Guys making 400 wheel horsepower on 24 lb injectors are probably running near a 100 % duty cycle,at a higher than 43 psi base fuel pressure.
If you can make a fairly accurate prediction of your crankshaft horsepower the calculator will get you close enough and tuning will get you the rest of the way.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
