Runners in a Tpi
Old May 8, 2010 | 07:39 PM
BAMNCO's Avatar
Car: 1987 Corvette
Engine: 383 Stroker
Transmission: 4 speed auto
Axle/Gears: stock
Runners in a Tpi
I read this runners add around 15 to 20 horse power. Also how will they work on a stock intake and straight pipes on a 87 vette ? thanks
http://www.summitracing.com/parts/SLE-20002/
http://www.summitracing.com/parts/EDL-3865/
Old May 10, 2010 | 06:34 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Re: Runners in a Tpi
They bolt on pretty easy to your car.
Maybe more like 10hp if that is the only component you change. Biggest improvement is that your power band would extend 200-500 rpm past 4,500rpm. I would stay away from Edlebrock, don't believe they flow much more air than stock. Plus I think they look crappy. Those siameesed runners are good. TPIS large tube runners are good too but more expensive.
http://www.tpis.com/parts/view/31
Stock runners are very restrictive so changing that will help your 350. Base manifold is also restrictive. What are you long term goals for car? Just asking since people usually do more than just larger runners and there are lots of intake options/upgrade paths you can take.
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
