L98 intake to LT1 intake questions
Old May 9, 2010 | 09:46 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
if i get an lt1 upper intake what would i need to change besides the throttle body and lower intake manifold?
Old May 9, 2010 | 11:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: L98 intake to LT1 intake questions
The LT1 is a one piece cast intake that takes a stock TPI throttle body ; there are no upper and lower parts like a TPI
Old May 10, 2010 | 11:33 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
dont forget you need to drill the hole for the distributer, get a distributer angled shim, fill the head bolt holes with JB weld and redrill the new hole pattern into the intake, and lastly you need to drill and tap the intake for the new coolant lines.. its a big job
Old May 10, 2010 | 05:10 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
ok thanks alot and to drill new head bolt holes, are they straight forward or do i have to maneuver around things and have a hard time drilling? and is there a thread showing how to do so because i could find anything
Old May 10, 2010 | 05:28 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Do a search, there are a few threads about converting the LT1 manifold to work with a traditional SBC...
Old May 10, 2010 | 06:02 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
You'll also need a remote thermostat. Do some searching around first like HCR13 said and you will find all the info for the swap. Good luck.
Old May 11, 2010 | 08:42 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
http://www.popularhotrodding.com/tec...ls1/index.html here ya go...I have it and I love it..you will have to extend the iac sensor wire and find a new home for it in the air intake,you will have to get you chip reprogrammed,cause there will be no egr valve,and no cold start injector..make block off plates for the egr,get a remote thermostat housing,extend the coolant temp sensor wires to the remote housing,drill the intake for the new bolt pattern,and the distributor...its a little bit of work..but you wont be running into a wall at 4800rpm no more..
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
