AC DELCO FUEL PUMP #
Old May 19, 2010 | 05:29 PM
GOATS2QUICK's Avatar
Car: 89 trans am / 67 gto
Engine: 350TPI
Transmission: AUTO
Axle/Gears: 3.27 9 bolt
looking for the correct part number for a replacement acdelco fuel pump for a 89 5.7 tpi. the parts stores in my area dont carry them, only airtex. ive seen a few on ebay, and want to make sure im buying the correct one.
Old May 19, 2010 | 05:41 PM
Guest
Guest
Posts: n/a
Re: AC DELCO FUEL PUMP #
The latest numbers I have (these may have been replaced with new numbers, entirely possible knowing GM) are:
#E3210 for the stock TPI pump
#E3270 for the TTA pump, which is the one I would order instead.
Old May 20, 2010 | 04:16 PM
p8dnful's Avatar
Car: '90 Iroc-Z
Engine: 5.0L 305 TPI
Transmission: Auto 700r4
Axle/Gears: 2000 3.42 posi with Disc
ACC-75703 Accel FUEL PUMP 85-92 GM 255 LPH its $143 from Summit. The stock AC Delco Fuel pump is like $15 cheaper at a GM Dealer. I just went ahead and went with the aftermarket
Old May 22, 2010 | 10:54 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
i went thru 8 fuel pumps that were ****. all were ac delco and airtex from my local parts stores. so i finally bought the walbro 255 for my car and never had a problem again. i guess they couldnt put up with the florida heat
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
