Aother carb to tpi swap... just a few questions...
Old May 20, 2010 | 03:03 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
i built a 305 chevy with vortec heads and a few other things...
i have pretty much just 2 questions...
is it possible to siames the stock styl runners? i see many post on doing this to aftermarket runnes. would it be beneficial to siamese the base intake? and since it is a dry manifold will it also be benecifial to polish the plenum and runners?
2- since i dont have money for a vortec base manifold, how will a set of pocket ported 416 heads flow compared to vortec 305 heads? which flow around 225 on the intake... im gonna pocket port then gasket match the intake and exhaust, and have the valves get a 30 degree backcut...
and also will it make more power than my current combo? which is vortec 520 casting heads (1.84/1.5 valves, completely stock), procomp square bore manifold, and an edelbrock 600 cfm carb. summit 1103 cam and headers...
pretty much it will be vs a stock tpi with ported heads, and the same cam and headers...
thanks
ox
Old May 22, 2010 | 03:05 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Aother carb to tpi swap... just a few questions...
Not a lot of metal to cut out on stock runners
Base is worth doing if you have time on your hands
https://www.thirdgen.org/siameseport
http://sethirdgen.org/TPIbase.htm
https://www.thirdgen.org/forums/post...545-post3.html
Port the plenum while you are at it
http://www.cis.udel.edu/~davis/z28/buildup/plenum/
http://forums.corvetteforum.com/c4-t...post1564474756
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
