Name that sensor!!!
Old May 31, 2010 | 09:43 AM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Name that sensor!!!
Cant figure out what sensor this is, I stripped the hell out of it and it still wont come off. This is from a TPI. Name that sensor!!!-img_3810.jpg
Old May 31, 2010 | 10:33 AM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
Re: Name that sensor!!!
coolant temp sensor
Old May 31, 2010 | 07:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Bit of a understatement
You might have to cut it off and carefully drill through it with bigger drill bits until you can break it out with out damaging the threads
New CTS
http://tpiparts.net/inc/sdetail/498
Old May 31, 2010 | 09:31 PM
Damon's Avatar
On the older TPI systems there is also a 9th injector temp switch down there. It's not a sensor, it's actually just a temp activated switch.
It's easy to tell apart from the CTS. CTS takes an oval 2 wire weatherpack connector, 9th injector switch takes a rectangular 2 wire plug.
Just thought I'd throw that in. I can't remember which hole takes which, but they're right next to eachother.
Old Jun 1, 2010 | 05:57 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Damon
I can't remember which hole takes which, but they're right next to each other.
Unless they have been swapped ,the CSI switch is on pass side and has the same style connector as the injectors
CTS shown circled in pic .CSI switch to left
Old Jun 1, 2010 | 09:04 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
So the sensor that I f'ed up is the one I need and the other one is for the 9th injector that I dont need cause Im running a 89 ecm? (Not worried about the TPI manifold, The sensors are for my HSR manifold.)
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
