Fuel injector voltage testing question
Old May 31, 2010 | 08:48 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
What is the proper way to check that fuel injectors are firing?
Old May 31, 2010 | 10:37 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Fuel injector voltage testing question
use a noid light
Old May 31, 2010 | 10:42 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
First test the resistance with a multi meter. Use the search option to find other threads with the specs. range. If they are good, you can use just a 1.5 volt battery and very quickly tap the prongs. You should hear a click. If a click is heard, it may be good. But if they are OEM, its best to buy a set of Bosch III's from a couple of sources that are faily cheap. Around $150 for a set of 8 and they have both 19 and 21 pounders. They are not, I say agian, they are not new, but they are take outs. In other words, they are fairly new. I got a set of 21 lbs and WOW!!! They do give a more smoother ride and less hesitation. The power is there when you floor it.
Old May 31, 2010 | 10:45 PM
Also, dont get confused with what is the firing order. Our TPI's are batch fire, meaning that the passengerside and driverside alternately fire (passengerside, driverside, passengerside, driverside, passengerside, driverside).
Old May 31, 2010 | 10:46 PM
This is not recommended at all, but if your that desperate, it's an option.
bryan623
Mar 22, 2021 06:43 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
