TPI fuel pump constantly runs
Old Jun 7, 2010 | 10:18 PM
Windowsrookie's Avatar
I'm swapping in 1987 TPI into my 1988. I've wired the tan/white wire coming out of the c100 connector to the tan/white wire on the fuel pump relay. The fuel pump kicks on when you turn the key to run, and shuts off when you turn the key to off. The fuel pump does not shut off after a few seconds like it should though. I can hear the relay click after a few seconds, but the pump continues to run. Also, if I disconnect the fuel pump relay, the pump still runs.
Anyone have any ideas to fix this?
Old Jun 7, 2010 | 11:01 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: TPI fuel pump constantly runs
Hmmmm, trying to remember. How about the oil pressure switch sticking?
Old Jun 7, 2010 | 11:07 PM
I can try unplugging the oil pressure switch tomorrow. Is there a fuel pressure switch at all? I don't believe there is, but I do still have the tbi pump in there, so it maxes out at 15 psi.
Old Jun 8, 2010 | 06:14 AM
BADCAM70's Avatar
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
Correct me if i am wrong but isn't the pump supposed to run as long as the ignition is on as the ecm feels the reference signal from the ignition module.
regards Mats
Old Jun 8, 2010 | 07:55 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
the ecm energizes the fuel pump circuit but there are safetys in line that will interrupt the current if something goes wrong.
if the f/p will not shut off it's most likely that the ops is stickey.
Old Jun 8, 2010 | 06:45 PM
I unplugged the oil pressure switch and the pump still runs. Any ideas?
Looking at the wiring diagram, the tan/white wire that the fuel pump connects to is just spliced into the the MAF relay, Fuel pump switch, fuel pump relay, and ecm. So if any one of those relays work wouldn't the pump be getting power?
When I turn the key to run, the pump continuously runs, but after a few seconds (when the fuel pump relay kicks off) the pump changes pitch like it has less power available. This is with the OPS plugged in or unplugged.
Old Jun 8, 2010 | 07:31 PM
Car: 1989 GTA
Engine: 369 TPI
You need to put a volt meter on the tan/white wire with the other lead going to ground. Sounds like your are getting some backfeed voltage on the tan/white wire. You will have to start disconnecting things until you find the source of the "unwanted" voltage. Do you have anything in the ALDL connector. Looks like if terminals D and A were connected somehow that would cause your problem.
Old Jun 8, 2010 | 07:56 PM
Nothing is in the ALDL connector. Where should I be testing the tan/white wire? At the fuel pump relay? I'm not exactly sure how the fuel pump should be wired into this either.
Old Jun 8, 2010 | 08:25 PM
Here is how it is currently wired. I'm not sure how the fuel pump is supposed to be wired in, here is how I have it.
Old Jun 9, 2010 | 08:18 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Reference signal from dist only happens when engine is turning
Key on; the ECM runs pump for 2 sec to pressurise rail , then stops,
When cranking the OP switch closes @ 4 psi causing the pump to run and when the ECM to sees that the pump is running ( from pump voltage back to ECM on pump control wire shown in diagram ) and the reference signal from dist it powers up the pump relay again.
Should pump relay fail ,the OP switch will keep pump running or allow you to start engine once OP over 4psi cranking
Old Aug 9, 2010 | 10:40 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
same problem I have, dont know why. my lb9 didnt have a fuel pump feed wire at c100? really confused
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
