tpi
Old Jun 24, 2010 | 03:37 PM
pjp209's Avatar
Car: Gone
tpi
when i try starting my car in the morning it spits out gas from that lil nozzel by the fpr on the fuel rail dont know why can anybody help me?
Old Jun 24, 2010 | 03:45 PM
pjp209's Avatar
Car: Gone
Re: leaking fuel rail 91 z28
Old Jun 25, 2010 | 12:18 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
thats the fuel pressure test port, the valve stem could be loose. Try tightening it up like you would a loose stem on a tire, i think you can use the same tool.
Old Jun 25, 2010 | 03:24 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
John is right, thats the schradder (sp?) valve and it used to test fuel pressure. Its the exact same mechanism as is on your tire valve stems. The core can be remove or unscrewed but you need a special tool. It could be the core is loose or gone bad (if possible) just buy a tool at walmart or some autoparts store or you can just go the junkyard and get the whole valve assembly from any fuel injected GM vehicle from the late 80s-early 90s... here is a pic so you'll know what you're looking at...
Old Jun 25, 2010 | 04:27 PM
pjp209's Avatar
Car: Gone
thanks ill try to fix it this weekend.
Old Jun 27, 2010 | 02:35 PM
HCR13's Avatar
Car: 1987 Trans Am
no problem, let us know how it goes!
Old Jun 10, 2011 | 07:43 AM
pjp209's Avatar
Car: Gone
4got to post...............it came out ok fixed it
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
