3000 rpm idle won't go away
Old Jul 10, 2010 | 03:07 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Here's the break down. The car is a 91 Z28 with an L98 swap. Right now the car will not idle lower than 2500-3000 rpm and I'm hesitant to 'let it warm up' at such a high range. The only code I pulled was for CTS low. IAC and TPS were just replaced and I didn't find any vacuum leaks. I have open shorty headers until I can make the car drivable enough to get the exhaust hung. Any help is appreciated.
Old Jul 11, 2010 | 12:54 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: 3000 rpm idle won't go away
Vacuum leak.
Old Jul 11, 2010 | 12:56 PM
theNMBR27's Avatar
can I get an under hood picture of all the vacuum lines
Old Jul 11, 2010 | 06:01 PM
theNMBR27's Avatar
checked ALL vacuum lines and now the idle dropped to 2500. I noticed I don't have a charcoal canister and the CTS needs to be replaced. Can those two things make my car run so poorly?
specialized
Jun 18, 2022 09:26 AM
19irocz85
Aug 26, 2015 07:54 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
perZ
Aug 15, 2015 01:17 PM
