SDPC Vortec Manifold Question??
Subscribe
Jul 13, 2010 | 04:52 PM
I am reassembling my 92Z and I don't remember what sensors and fittings go in which holed at the front of the manifold. I believe the stock base was a little different.
Also the SDPC kit came with a connection that attached to a pipe on the header and to the base. I have two questions about this:
1. Does this pipe need to be connected? Is it possible to block either end without causing any smog or running problems?
2. There is a threaded opening on the outside of the connector that was now noted in any of the instructions. Can this be capped?
Thanks,
Jim
Reply 0
Subscribe
