Hunting at idle...o2 related
Old Jul 30, 2010 | 05:31 PM
SS ninja's Avatar
Engine: 5.7 vortec crate w/TPI
Transmission: 2004r
I've found a couple of topics on here related to hunting at idle, but no-one seemed to have the same symptoms I have, so I thought I'd post up looking for ideas.
My setup:
Stock '730 ECM
GMPP 350 HO crate motor
Holley Stealth Ram
Kirban adjustable FPR set at 50 psi
The issue:
My car will idle fine when cold, but once it starts to warm up (And enter closed loop), the idle will start to hunt up and down about 100 RPMs, occasionally starting to stall and recovering, with an occasional stall. This will occur in park or drive.
The car has no issues restarting, and will idle fine for a minute on restart before the hunting starts again.
I've checked the TPS, IAC, timing, CTS, etc and seem to be fine.
On a hunch I disconnected the o2 sensor, which smooths out the idle even when warm.
Thinking the o2 sensor was bad, I replaced it with a new one today. This didn't help, as the car still wants to hunt when warm.
Any ideas for where to go from here?
Old Jul 30, 2010 | 07:50 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Re: Hunting at idle...o2 related
Next time it starts hunting disconnect the IAC connection. If it then runs smooth that is your problem. My car does the same thing but doesn't die and it is the IAC. But it sounds cool, like a top fueler at idle so I leave it alone.
Old Jul 30, 2010 | 09:55 PM
SS ninja's Avatar
Transmission: 2004r
Well, that's the thing. I'll try the IAC again, but the last time I did check it that didn't affect the idle at all, while disconnecting the o2 sensor does affect the idle (It smooths out).
This is with the old o2 sensor and the new one I just picked up.
Old Aug 2, 2010 | 11:57 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
did you test your injectors?
how about ignition do you have good spark and timing?
if it smooths out disconnecting the O2 then you are just telling the engine to go back to open loop. so it is not reading O2 anymore ergo, not impacting injector pulse and timing.
Old Aug 2, 2010 | 06:16 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
loosen your distributor and with the engine running and the est wire CONNECTED move the distributor back and forth and see if it will run better. The reason I say to do this is because the mark on the balancer can actually move and make you time it way off. just try it you got nothin to lose
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
bbsr72
Apr 2, 2016 09:12 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
89newfun
Sep 16, 2015 09:28 AM
