fuel injector castin number
Old Aug 4, 2010 | 12:33 PM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
I pulled some injectors off my 92 camaro that I was told had a 91 vette engine in it..im tryna see if this is true or just has the stock 305TPI engine or a 350 swap..the numbers on the old ones are 17066452 and 9120 wit W21 on the injectors as well..i installed 92 camaro 350 injectors on it now...
Old Aug 4, 2010 | 01:00 PM
Re: fuel injector castin number
I mean the numbers are 17086542
Old Aug 4, 2010 | 02:12 PM
southbay08's Avatar
The part number 17086542 is a 19lb injector that is rated at 43.5psi..... good for a 305
Old Aug 4, 2010 | 02:47 PM
[QUOTE=southbay08;4631558]The part number 17086542 is a 19lb injector that is rated at 43.5psi..... good for a 305[/QUOTE.
I kinda thought that myself it was a 305...well I putt 350 injectors on it...it runs fine other then it seems it doesn't have the power it should...will it hurt anything by leavin the new injectors in....
Old Aug 4, 2010 | 03:44 PM
would that hurt anything running 24lb in a 305...it runs some what good...just seems it doesn't have the power it should have...
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
