stalls
Old Aug 5, 2010 | 03:52 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
stalls
So i've got a totally fresh TPI install. Runs very well, idles great, base tune is totally driveable (AXCN bin). But i'm running into one issue, when you come down from 2k rpm and put in the clutch, car stalls. I figure this is a VSS issue, but is there anyway to tune that out? can i connect just to the vss buffer box (and how?)
I have a speed sensor coming that has a cable output (i need cable output for my speedo) and the electric sender, but i'd like to know if there is a way to keep it from stalling until it arrives (2-8 weeks!)
Old Aug 10, 2010 | 10:46 PM
TG Goose's Avatar
Engine: 355 SD TPI
Re: stalls
ok, well since no one here provided any ideas I can only say that fixing this problem came down to installing my VSS adapter (painless 60116) and then re-setting the base idle by disconnecting the IAC.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
