capped pcv
Old Aug 6, 2010 | 07:28 PM
xxpotandaxx's Avatar
Car: 1992 Camaro z28
Engine: 5.0 TPI
Transmission: 5 Speed Manual t5
capped pcv
Ok so i capped the pcv outlet coming from my intake My car isent gunna blowup into a million pieces right?
Old Aug 6, 2010 | 08:06 PM
Engine: 5.0 TPI
Re: capped pcv
Help anyone??
Old Aug 6, 2010 | 08:20 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: capped pcv
prepare yourself for oil blowby from places that you never knew existed . don't do it . chose to ignore , o.k. you will suffer . just my . good luck .
Old Aug 6, 2010 | 08:35 PM
Engine: 5.0 TPI
Re: capped pcv
then what should i do?
Old Aug 6, 2010 | 09:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: capped pcv
Why did you cap it?
PCV system is there to remove fumes from engine and as noted above without it pressure will build up in crankcase forcing oil out somewhere
Old Aug 7, 2010 | 02:53 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: capped pcv
Originally Posted by vetteoz
Why did you cap it?
Old Aug 7, 2010 | 05:50 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
Re: capped pcv
i had 2 pcvs in my car when i got it and it ended up shooting oil out the dipstick and pushing out both of the valve cover gaskets. make sure you have one pcv and ccv to balnce each other out and you'll be fine
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
school boy
Oct 22, 2015 11:47 AM
LT1Formula
Oct 8, 2015 08:34 PM
Damon
Sep 26, 2015 04:29 PM
