TPI FUEl PUMP KEEPS BLOWING FUSE ???/
Old Aug 15, 2010 | 09:24 AM
64gtoguy's Avatar
MY TPI fuel pump keeps blowing the 20 Amp fuse,,,,,, question is. is the pump going bad ? or is something elso going on ?
Old Aug 15, 2010 | 05:26 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: TPI FUEl PUMP KEEPS BLOWING FUSE ???/
Check the wiring on the relay plugs on the fuel pump relay and maf relays, over time the insulation can slide down exposing the bare wire and causing a short that will blow the 20amp fuse. This happened on my 86, once I insulated the wires the fuse stopped blowing
Old Aug 15, 2010 | 05:31 PM
64gtoguy's Avatar
I found out why the fuse is blowing,,, when the cooling fans turn on, the fuel pump fuse blows,,,,,,, ?????? any one have any suggestions?
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
