SLP Hardware
Old Aug 27, 2010 | 02:13 PM
Mr. Notorious's Avatar
SLP Hardware
Can anyone tell me the dimensions on the hardware for the SLP runners? I bought a used set that didn't come with the bolts and I don't even have the factory hardware to get the thread diameter and pitch from. They want $36 for replacement set, but it's only what, 18 bolts? If anyone can help it'd be greatly appreciated...
Old Aug 30, 2010 | 07:57 PM
Re: SLP Hardware
bump?
Old Aug 30, 2010 | 08:23 PM
Guest
Guest
Posts: n/a
Re: SLP Hardware
The length you can measure yourself from the runners. Measure where the bolt goes through, and add 1/2". Adjust to nearest larger size, the holes are all at least 3/4" deep in the base. You need at least 5/16" into the base and plenum, including the gasket and given that its aluminum dont use bolts that are too short. The factory thread is 8mmx1.25.
Old Aug 31, 2010 | 07:46 AM
Re: SLP Hardware
Much appreciated. I didn't have any labeled metric bolts to determining what the base what tapped to
Old Sep 1, 2010 | 11:02 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: SLP Hardware
You can get a nice set of stainless or polished bolts on ebay, got mine there because the SLP hardware rusted in a matter of days
Old Sep 2, 2010 | 07:41 AM
Re: SLP Hardware
Good point. I did check, I think it was TPIS website, and they wanted like $38 with shipping for the 12 bolts or whatever it was. $3 a bolt!
Old Sep 2, 2010 | 10:25 AM
F-Body Demon's Avatar
Re: SLP Hardware
Yeah I just bought a set of bolts from my local hardware store for my SLPs. Bolt is a bolt if you ask me. Im not building the Mona Lisa of GTAs.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
sjorgens
Oct 1, 2015 07:54 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
